Wilwood caliper ear thickness
Old Apr 2, 2007 | 08:40 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
For those with Wilwood FSL calipers, how thick are the ears? The spec sheet pdf gives dimensions from the outside (towards the rotor) of the ear to the rotor centerline, but not from the inside (where the caliper gets mounted to the bracket). Thanks!
Edit - I just called Wilwood when they opened, and the ear thickness is .700" for the forged billet superlite (FSL), Superlite 4 (SL4) and Superlite 6 (SL6) calipers. The difference between the $165 FSL calipers and the $300 lug mount SL4's is just the differential bore piston sizes (1.88 & 1.75 vs 1.75x2 for the FSL), according to the Wilwood tech, which doesn't jive with their website. The SL4 & SL6 also have four bolts strengthening the caliper, in addition to just the 1 bridge bolt on the FSL.
Old Apr 2, 2007 | 11:39 AM
HPE's Avatar
HPE
Re: Wilwood caliper ear thickness
It is .700.I answered you over on Frrax also with more details
Old Apr 9, 2007 | 07:03 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Wilwood also said .700"... I did the CAD models for the brackets based on this thickness, and when I received the calipers and measured, it turns out that the ears are actually .625" thick. Maybe there's a difference between the 4 piston FSL's and the 4/6 piston differential bore superlights. Oh well...
Old Apr 9, 2007 | 11:56 AM
HPE's Avatar
HPE
I promise you my radial mount brackets have ear tab widths of .700. I still have that dimension written down from when I physically measured them myself with a digital caliper. Thats why I opted to leave mt secondary brackets I had custom made the same .700 thockness and aluminum to match Wilwoods own bracket material and thickness. I also had mine ceramic coated for heat dissapation so they would be less likely to absorb heat and expand causing loose bolts- i also safety wire everything.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
