11 3/4" front discs?
Old Apr 22, 2007 | 12:22 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Stock discs are 10.5" my car is a G92 car, NOT a 1LE car
Just ordered some slotted rotors, putting them on the car and =| they dont fit, go measure the disc off the car and its 11 3/4" around...What do i have on my car, did someone change my brakes to 1LE brakes?
Old Apr 22, 2007 | 12:45 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: 11 3/4" front discs?
Got pics? What do your calipers look like?
Ed
Old Apr 22, 2007 | 12:55 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
front caliper
front spindle
rotor
rear caliper just for fun
Old Apr 22, 2007 | 01:30 PM
ebmiller88's Avatar
Those are 1LEs front and rear, my friend, you got great brakes.
Ed
Old Apr 22, 2007 | 08:11 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
why do i have these on a non 1LE car? its a 90? is this factory or no?
Old Apr 22, 2007 | 10:02 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
and am i going to be using the same size wheel bearings inside and out for the larger disc?
Old Apr 23, 2007 | 12:51 PM
ebmiller88's Avatar
Is your car a B4C or police package car? They got them too. Maybe someone installed them for you, I can't tell you. Factory or not, you have them.
Old Apr 23, 2007 | 01:15 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
this is all starting to come together a little, a while ago when changing a u joint i realized i have an aluminum driveshaft, my brakes are 1le and i have a 36mm front sway bar which i dont think is stock, one of the previous owners must have found a totaled 1le car or something to the liking and stripped everything of value off it.
What i really need to know now is if i need to get different sized wheel bearings then stock? and what parts it is that i need for that swap
Old Apr 24, 2007 | 10:43 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
ah crap, eb would you happen to have a picture of the 1LE front caliper assembled. Its pretty straight forward but im forgetting things like which way the slider bolt went in
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
overdriv
Aug 20, 2015 03:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
