LS1 front brake swap help!
Old May 6, 2007 | 08:27 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
well i have all of the factory stuff removed that part went ok. i got my swap kit from ed miller which is very nice! but here is my problem i put the new spindle on the a-arm lower ball joint i tightened the nut down as far as i can go and there is still a little bit of play in between the two. i called my dad to see what his thoughts were he said sounds like i ran out of threads so i might need a spacer between them but i have not seen any one on here talking about this problem any ideas?
Old May 6, 2007 | 02:03 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: LS1 front brake swap help!
fixed used a big washer.
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
