Flushing brake system??
Old May 7, 2007 | 09:03 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I just did a complete rebuild on my front end brakes. New rotors, pads, calipers, caliper pins, inner and outer wheel bearings. I'll hopefully be doing the lines soon too.
My big question is, after spending the time to install new parts, its now time to bleed the brakes. I have a feeling that the fluid is VERY old and I'd like to flush as much out as I can.
What is the most effective way to do this? Open the valves and push the pedal? I am a lone guy in my apartment parking lot so its gotta be reasonably simple.
Old May 7, 2007 | 09:25 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: Flushing brake system??
Brake fluid is very prone to moisture contamination as it ages.Flushing/changing the brake fluid is a very good idea.There are tools that you can use to do the job by yourself.Here's a couple examples to give you an idea.
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Old May 7, 2007 | 09:45 PM
jetblast's Avatar
Car: 91 z28 convertible
Transmission: 5 speed
I just upgraded my brakes to C5 and LS1 for the rear. My fluid was black, so when I changed the calipers I let all the fluid drain, and started from scratch. I also dont have any body to help me out. So I used a peanut butter glass container and a clear plastic hose that fits the bleeder. Then I filled the container half way and installed the hose to the bleeder and the other end goes inside the container. You have to make sure that the end inside the container always stays under fluid. Then just fill the reservoir with new fluid and start pumping the pedals. Also you want to start on the rear right then rear left, then front right, then last front left.
Old May 7, 2007 | 10:30 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
I would recommend the following method.
Open up all the bleeders and let them drip. When the master cylinder gets low add more fluid. Do this until you have filled the master cylinder up twice and tighten the bleeders. I doubt that you will have any air in the system and will have all new fluid.
Old May 8, 2007 | 01:32 PM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
I like using a vacuum pump to completely drain the system and then using it again to draw the new fluid through the system. For overkill, I also have speed bleeders on each of the calipers.
Old May 10, 2007 | 12:19 PM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
A guy at a parts store told me to do the gravity draining thing, just by opening the bleeders and wait. I have not tried it yet so I'm not sure.
Related question, hope I explain this well,
Should you ever bleed from the block directly under the master cylinder? It has 2 lines going into it from master cylinder, then the front part has 1 out and the rear part has 2 out. I think they are separate. both front side and backside have a large but thin hex nut with a nipple thing. Should bleeding be done from here followed by bleeding each line at the calipers?
Also, anyone know where I can find a diagram or something of how the parts inside this aluminum block work, just out of curiosity.
Old May 10, 2007 | 01:31 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Just taging on. Wanting to see what everyone suggests.
Old May 10, 2007 | 09:36 PM
SDIF's Avatar
Leave the block thing alone.
Just bleed the calibers.
You may be asking for trouble by playing with the distribution block.
Do the gravity bleed.
Old May 10, 2007 | 09:42 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
So with the gravity bleed, you dont have to do the old "pump and hold" method at each corner right.
What about if you replace the rubber lines. Can you still gravity bleed them?
Old May 11, 2007 | 07:04 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
If you have black fluid and your rubber lines are more than seven years old, you OUGHT to replace them!
...and yes, you can gravity bleed through new lines. However you might have better luck by using a mitey-vac, which is a little hand pump that you hook up to the brake bleeder screw. It pulls a vacuum which sucks air out of the caliper and lines. You dab some silicone grease around the bleeder screw to seal it, then start pulling a vacuum on the caliper. Keep pumping until no more bubbles appear. It's truly a one-person job and a worthwhile tool for your box.
Old May 11, 2007 | 07:11 AM
Engine: 305ci TPI
Well, I was thinking the "gravity" bleed is if you were to open up the bleeder valves and then... just wait. no pumping the pedal, just wait until the fluid trickles down but make sure the master cylinder keeps fluid in it. im not even sure how well the fluid will flow like this.
I'm probably going to buy the vacuum pump at advance auto for $50 so I can stop relying on people to help me bleed. Plus you can play with other vacuum operated stuff.
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
LittleFranks
Sep 17, 2015 12:22 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
zayne0
Aug 24, 2015 07:22 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
