front 1LE-brake cable has no adjustment??...
Old May 22, 2007 | 04:06 PM
dr_vlahos's Avatar
I just did the drum to rear disc 1LE brake conversion on my 1990 firebird.Every thing went smooth except for the e-brake set-up.
I bought 2 new left and right e-brake cables and hooked them up, but my front e-brake cable going inside my car has no adjuster....
I looked inside the lever console and under my car, above the driveshaft and only see a small cable with a t-clip that holds the 2 L & R cables together...
I called GM today and my local parts store for a disc brake front cable and both say that this front cable has been discontinued and no stock in North America.
Does anyone out there have any suggestions on where I can get this cable from??
thanks
dr_vlahos
Old May 22, 2007 | 06:25 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: front 1LE-brake cable has no adjustment??...
On 1990-1992 there is no adjustment provision above the driveshaft. You can swap in an older one and you'll be fine, just gotta find one.
Ed
Old May 22, 2007 | 07:45 PM
dr_vlahos's Avatar
So, what year of front e-brake cable should I look for??? 87,88,89 ????
Dr.
Old May 23, 2007 | 05:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I believe 82-89 were all adjustable.
JamesC
Old May 23, 2007 | 06:39 AM
Z.ROC28's Avatar
Car: 1991 Camaro RS
Engine: 305 L03 TBI
Axle/Gears: 4th Gen 10 bolt posi / 3.43
I just ran into this problem with my fourth gen rear end swap... We got the rear end in but we were losing brake pressure for some reason. Then my dad remembered his 94 Z28 and how someone told him to adjust it. It's very simple. Just sit in your car and jank the E-Brake a several times and you start to feel it tighten. It might take a few minutes but mine work perfectly fine now. Edit: I forgot to mention, you MUST use your e-brake all the time because that's the only thing that keeps them adjusted!
Old May 27, 2007 | 08:53 AM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
I may be able to chime in.
Check to see if your spring is bound like this fully applied.
If it is you need to get the other style cables and use a dremel to open there slots up to fit over the caliper e-brake bracket.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
dcbsracing007
Aug 18, 2015 07:24 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
