rotor cleanup, rust removal
Old Jun 2, 2007 | 10:04 PM
lowgas&rubber's Avatar
Car: 97 b4c camaro
Engine: 350 lt1
i am buying a car that has sit for a while and has rust build up on the rotors. what steps can i take to get the rust off of them and restore to near perfect condition? any advice would help, thanks
Old Jun 3, 2007 | 08:05 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: rotor cleanup, rust removal
Just drive the car and use the brakes, that will clean up the rust. Nothing on these cars will look factory new again.
Old Jun 3, 2007 | 08:21 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Before you do anything to your existing calipers check the parts places for the price for re-built calipers. Most of the early models are available for around $12 each. Even the later ones are cheap enough where I wouldn't spend the time cleaning and rebuilding.
If you install rebuilt calipers, just clean them up real good (they're usually coated in a light oil) and paint them before installing.
Krap, you're talking about the rotors. If they're too bad you can have them turned by a shop. If it's just light surface stuff the brake pads will take it off. I'd call around for prices to turn them, seems like there's a big variance in price, at least around here. One place wanted $12 per to slap it on a machine and let it spin for 5 minutes, sheesh.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
deracer
Apr 11, 2016 12:04 AM
3rdgenparts
Aug 8, 2015 07:09 PM
