pbr disc brakes
Old Jun 6, 2007 | 12:54 AM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
pbr disc brakes
can you run pbr disc brakes off a drum proportioning valve?
Old Jun 6, 2007 | 06:05 AM
84TranzAm's Avatar
Car: 84 TA Black/ Gold
Engine: 383 With Vortec Heads
Transmission: 700 R4 Lvl2 Performabuilt 9.5 Vert
Axle/Gears: Moser 9" with 3.70
Re: pbr disc brakes
No you need to get a proportioning valve off a disc set up , for it to be set up properly. Some people have used the drum valve and used an optional adjustable valve to compensate. I bought my valve off of ebay for 6.08 including shipping . Just make sure to get one off same generation. With yours being a 89 I would say to go with 84 and newer to make sure you get the right metric bubble fittings on the valve.
Old Jun 6, 2007 | 12:45 PM
Engine: 383 HSR EBL
Re: pbr disc brakes
thanks
Numbah-1
Sep 12, 2015 08:57 PM
64Chief
Sep 12, 2015 08:05 AM
drb930
Sep 9, 2015 10:53 PM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
