NAPA remanufactured cailpers...
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Hey all. I am needing to replace my front calipers an was wondering if the remanufactured ones would be ok? I want to upgrade the front brakes in the future, but right now I just need them to work
Thanks in advance.
Thanks in advance. Joined: Aug 1999
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 06' chevy 1500 and 84' z28
Engine: 305 with an unknown cam and heads
Transmission: 700-r4
Axle/Gears: its an open rear 3.48 or 3.73?
Re: NAPA remanufactured cailpers...
I worked in an auto shop (goodyear) for a few years and found the reman calipers and other parts are good. the only problem i ever had was if you get "loaded" calipers, thats when the pads are in the box, they were cheep and made a loud metal noise. go with a good set of pads.
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
I replaced mine from advance, all the same. MAke sure to replace the hoses at the same time. Its worth it.
Car: 1991 RS Camaro
Ok, thanks guys. I'm not going to get the loaded calipers. I'm going to re-use the Hawks pads I have on the car. They are about a year and half old. Going to get some Earl's lines from Spohn. I may also get new rotors if needed.
Street Lethal
Apr 30, 2019 12:14 PM
luvofjah
Sep 26, 2015 08:28 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
red rock
Sep 4, 2015 03:42 PM
