Need help with LS1 Swap - Prop. valve
Old Jun 22, 2007 | 12:01 PM
82 Indy Z's Avatar
Car: 1982 Indy 500 Pace Car Replica
Engine: Stroked 350 (385ci) TPIS Mini-Ram
Transmission: 6-speed
Axle/Gears: Stock w/Disks and 4.10's
Trying to get all my ducks in a row before I make the big brake swap.
I have an 82 Camaro with rear disks. I want to swap the LS1 calipers and Master Cylinder. I noticed that the lines on the LS1 master cylinder are different from the original and that the lines going into the prop. valve are also different. What proportioning valve can I swap to make this work? Other option is to make new lines and using the original prop. valve? Are their any adapters I can use to make this easier?
Thanks in advance,
Old Jun 24, 2007 | 08:47 AM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Re: Need help with LS1 Swap - Prop. valve
I think you're going to need to get a flare tool and get the right size fittings for a later model 3rd gen and get the 1LE prop valve. They used different flares and (I assume) fitting sizes until 84 but after that I think there were also some different sizes. I may be wrong and it may be much easier than that but from what I've gathered that's probably what you'll have to do because I've heard that the LS1 master will bolt right up to my 91.
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
reiderz iroc
Aug 13, 2015 04:57 PM
