Caliper won
Old Jun 25, 2007 | 12:43 AM
zapr's Avatar
Car: 1985 camaro z28
Engine: 305 lg4
Caliper won
.........I just finished installing new calipers and rear brake cylinders and bled the system starting with the master cylinder. Problem is, the passenger caliper won't bleed. No fluid with bleed through the bleeder valve. A buddy said the flex hose is collapsed. Any ideas? Thanks.........Zapr.
Old Jun 25, 2007 | 06:56 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Caliper won
its a good bet that the hose is the problem . with age they can do that .
UNCLE TOM
Old Jun 26, 2007 | 01:49 AM
fastcar06's Avatar
Car: 1991 pro street formula
Engine: 355
Transmission: turbo 350 w/ 3200 stall
Axle/Gears: 9" ford detroit locker w/ 456
Re: Caliper won
disconnect the hose from the caliper and see if it flows. that'll tell ya.
Old Jul 2, 2007 | 08:21 PM
zapr's Avatar
Engine: 305 lg4
Re: Caliper won
........Turned out I had to replace both flex hoses, but that's what it was. Thanks for the help. Sorry about the double post........Zapr
Old Jul 2, 2007 | 08:29 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: Caliper won
That's usually the problem, the hoses are old and get clogged. Replace rubber hoses regularly, every 5 years or so.
Ed
Bubbajones_ya
Oct 25, 2015 08:01 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Luigytico09
Oct 1, 2015 08:46 AM
the_hamturdler
Sep 30, 2015 12:50 PM
