1988 4th gen brake ?'s
Old Jul 10, 2007 | 05:08 PM
BadZSS06's Avatar
Car: 2006 SS 2.0 Cobalt\88 383 Camaro
Engine: 383 Afr 195, 850 cfm hp
Transmission: Dynamic Racing 700r4
Axle/Gears: 9in Ford 4.11 Detroit locker
i just have a couple of quick questions. i have a 1988 camaro converted to a v8 and the v6 brake in the front are not cutting it any more. i have 17' iroc replicas on the car and i would like to keep them. i just bought all tubular front suspension and would also like to keep that. is this going to be possble and what would i need? thanks john
Old Jul 10, 2007 | 05:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 1988 4th gen brake ?'s
FYI: The V-8 and V-6 brakes are identical. For more info, check the stickies at the top of the page.
JamesC
Old Jul 12, 2007 | 04:35 PM
Legal Disaster's Avatar
Car: 1986 Iroc-Z
There are several routes you can take here, you can go for the 1le brakes, which I believe are the same as c4 corvette brakes, or close to it at least. Then there is the option of running 4th gen camaro or c5 corvette brakes. The 4th gen brakes would work with factory 16inch weeks, and c5 need a 17inch minimum sized rim, which you already have. Take your choice which way you'd like to go with it, the 4th gen brakes would end up cheaper to get parts for, ie rotors, pads, etc. The c5's would offer a tad more braking power and fill up the space between your wheels more.
Most require the same modifications to the spindles, and require the use of brackets. There are many ways to go about this, buy them or build them yourself. Check out some of the stickies and faqs and you will get all the info you need to do the swap.
sweet_87_iroc
Sep 25, 2015 10:01 PM
cam-mike
Aug 24, 2015 07:23 AM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
