Prop Valve
Old Jul 26, 2007 | 05:48 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Prop Valve
Can anyone answer what prop valve to use when upgrading 86 rear disc to the PBR style disc. I know that the prop valve needs to be changed but do not know which one to use.
Thanks for your help.
Old Jul 31, 2007 | 10:17 PM
Iroczracer's Avatar
Car: 1989 IROC Camaro
Engine: Stealth Ram 355
Transmission: WC T-5
Axle/Gears: Torsion 3.42 Posi
Re: Prop Valve
I'm not sure on the TA!! If it is like the Camaro, you should not have a problem if you have J50 brake system.
Old Aug 1, 2007 | 12:31 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: Prop Valve
You need the first design 1LE prop to be correct, I have 4 on hand.
Ed
Old Aug 4, 2007 | 07:08 PM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
Re: Prop Valve
Ed - Is this GM part number 14089496?
Old Aug 5, 2007 | 05:56 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Prop Valve
14089496 1989 1st design: M1.0 tube nut threads (For 1982 - early 1989 applications)
10136840 1989 2nd design: M1.5 tube nut threads (Late 1989)
10136840 1990-'92: M1.5 tube nut threads.
The following link may be helpful:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
Necron
Brakes
Sep 14, 2015 12:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
