wanna upgrade my brakes....z06
Car: 87 IrocZ/87 Iroc Z28
Engine: L98 350 TPI/ LT1 350
Transmission: BW T5 5spd/ 700r4 A4
Axle/Gears: 10 bolt posi 4.10/10 bolt posi 3.73
yeah, im tired of my brakes and want to upgade to something that will be good, but wont burn a hole in my wallet. i was thinking of some z06 brakes/ rotors since i want to put some z06 rims on as well. what do you guys think? know a good place to pick these up?
Car: 1989 IROC Camaro
Engine: Stealth Ram 355
Transmission: WC T-5
Axle/Gears: Torsion 3.42 Posi
Re: wanna upgrade my brakes....z06
The Z06 disk brake upgrade is an excellent upgrade....My original plan was to install Z06 disk on my 1989 IROC, But changed in mid stream. For cost I chose the LS1 disk upgrade, and did not want to change my Center Lines. Used LS1 drilled, slotted, and coated rotors, hawks pads. On the rear is 93 Z28 drilled, slotted, and coated rotors, hawk pads. This should provide good braking, and use my 16" wheels...
how much more would the z06 brakes cost than the ls1's? do you like your set up
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
What size wheels are you running? C5 Z06 brakes require 17" wheels at the minimum.
Ed
Ed
dbrochard
Sep 25, 2015 04:56 PM
