91 Brake Swap
Old Aug 28, 2007 | 10:55 PM
K-dawg's Avatar
Car: 94Chevy s10, camaro is soon to come
Engine: 4.3L TBI Vortec
Transmission: 5 speed manual
Axle/Gears: I believe it's a 3.55 possi
91 Brake Swap
I have a 91 rs that currently has a front disc rear drum setup on it, I am seriosly thinking about putting a 4th gen disc brake rear axel, and I have a few questions.What all else would I need to make the rear brakes work?are the internal gears interchangeable?would I be able to use the stock wheels on the rear?if I have to put 4th gen wheels on it would the 4th gen front wheels bolt onto the stock third gen disc brakes, if not what kind of front brake upgrade should/can I do to make them work?I would also like to use more swapped parts from rather than from high end after market companies?(I having nothing against any of these companies, but my wallet does)
Old Aug 29, 2007 | 11:06 AM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: 91 Brake Swap
Take the whole 4th gen rear and it bolts right in. Yes the 4th gen wheels fit the rear perfectly, no the stock one's stick out to far and rubed. Spacers are needed for the front 2"-2.25", to run 4th gen's. I have 2.25" for mine. You also need to get an adjustable proprtining valve, or a stock 3rd gen disk/disk prop valve.
http://stores.ebay.com/EZ-Accessory_...QQftidZ2QQtZkm
this is where i got mine there cheap, good, and very fast delivery like two days i think it was
Old Aug 30, 2007 | 08:16 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: 91 Brake Swap
I got a 1LE prop valve and a 4th gen master cyl. to do my 4th gen rear swap! I also have aftermarket ZR1 rims that required a 2.25" spacer for the fronts.
Old Sep 1, 2007 | 09:33 PM
K-dawg's Avatar
Re: 91 Brake Swap
has anyone used z06 vette wheels with this swap? if so can I see pics?
Old Sep 1, 2007 | 09:59 PM
krisb410's Avatar
Re: 91 Brake Swap
They wil work great, I got ZR1s
Frozer!!!
Jan 19, 2024 04:55 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
