constant squeaking driving me nuts!!!!
Old Oct 8, 2007 | 12:30 PM
jaseman2134's Avatar
Car: 1987 camaro
Engine: 3.1
the sound is coming from my driver side well, brakes do not affect the sound and it progresses with speed. turning the steering wheel doesnt change it either. i took the wheel off and checked pads(about 1k miles left on em), the wheel bearings weren't damaged. rotors are smooth. i did a 95-0 stop in roughly 350meters on the highway to avoid hitting some jackass that was on his cellphone two weeks ago. could i have warped or glazed the pads? i started bashing my head against the steering wheel today and im not sure how much longer I'm gonna be able to handle it without a taking a nail gun to it. any advice is appreciated. thanks
Old Oct 8, 2007 | 05:17 PM
Duracell Bunny's Avatar
Re: constant squeaking driving me nuts!!!!
squeak or squeal?
Constant sqeal is a wheel bearing.
squeaking (mostly intermitant ) can be the pad compound being too hard (IE racing pads).
You may have overheated the pads and left pad buildup on the rotors thus giving a slight pulse feeling and a horrid sqeak every time the wheel rotates.
You were doing 95mph and he's the jerK? Sometimes you should proofread before you post. THis does not make you look good in your own admitance.
Old Oct 8, 2007 | 06:25 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
LOL i dont care that you were doing 95 or 10 jerks on cell phones **** me off..........hint air horns from a dump truck help out, they think they are fixin to die look up and see a car......i dont want to make you seem dumb but i got to ask is the wear indicator rubbing on the rotor? not tring to make you look like a tard, but even the best mechanic can over look something sometime, i had a set of brakes on my van that made a squeek all the time i got mad finnaly and got a set from JC Whitney.... Titanium ti22 is the brand name they have them for camaros also, hardly any brake dust and the are quiet and stop real good for the price 29.99, they have lasted a long time also
Old Oct 8, 2007 | 07:23 PM
Car: 1987 camaro
Engine: 3.1
hehe, I get a bit of a lead foot. and they were braking in the fast lane for no reason that I could see(forgot to mention). but yea, I should still follow the 55mph limits. For the wear sensor, when I checked it last weekend it was roughly 1/8"-3/16" from touching the rotor. I'll take it apart next weekend and look for the buildup. I'll take another look at the bearings too(forgot to check the inner bearing). thanks for the heads up on the pads, I'll give them a try next when I get rid of these. if it turns out the rotor does have some buildup, what is the easiest way to get it off? Thanks for the info guys
Old Oct 8, 2007 | 10:42 PM
Have them turned on a brake lath. That will get rid of the pad buildup. You should just put new pads on also at that time so they re seat properly to the new rotor surface.
Old Oct 9, 2007 | 07:02 PM
89RS_82Z's Avatar
yea i know o'rileys does it around here, not sure of the other major retailers but they can normaly turn rotors cheaper than anyone else unless you got a friend in high places......BTW another JC Whitney good deal is there slotted and drilled rotors, 69.99 a piece, a little more than standard rotors at your local parts house, but if you want good slotted and drilled for a good price you cant go worng, put them on my satty and camaro, no problems, just a thought for ya
off the subject, but why do people insist on driving slow in the fast lane, out there not passing, just off in there own world?!?!? Driving trucks, that really makes lots of us mad
Old Jun 9, 2008 | 10:59 PM
Car: 1987 camaro
Engine: 3.1
totally dead thread and i haven't been on here in months, but i completely agree. over 90mph is a bit overboard but doing 55 in the fast/passing lane gets me antsy haha. and thanks for naming those brakes, 89RS_82Z, i put em on last week and they work great
jklein337
Sep 19, 2018 06:23 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Omega
Oct 1, 2015 02:20 PM
lakeffect2
Aug 23, 2015 08:44 AM
mustangman65_79
Aug 8, 2015 12:07 PM
