Braking issues
Old Oct 18, 2007 | 12:19 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Braking issues
Hey all,
I have a 91 RS disc/drum that has some issues when braking. When I first start the car (and everything is cold), the brakes are so touchy that i barely press them and they lock up (on the rears). Once everything "warms up", the problem goes away. It is especially bad when rolling like through a parking lot when I dont need to press the gas pedal.
Also, I had replaced the rotors not to long ago (a little over a year ago, maybe 8 or 10K) and when braking at high speed (40+), sometimes the steering wheel shakes (slightly to violently, just depends sometimes), and sometimes the whole car itself shakes (as the steering wheel shakes), and then there are also times that nothing happens and it stops like champ.
Any thoughts on what it could be?
Thanks in advance,
-Tim-
Old Oct 20, 2007 | 06:57 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: Braking issues
Other than the rotors (and probably pads), what have you replaced? With 200K on it, it could be a lot of different things. I suspect leaking wheel cylinders on the rear allowing air into them causing the rears to lock up. I had this same issue in the past on an old truck. I also suspect the front calipers not sliding properly and causing the front to shimmy. I recommend a full disc upgrade or at least a full rebuild front and rear: rotors, calipers, pads, bearings, all flex lines, wheel cylinders and shoes.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
dyeager535
Aug 28, 2015 08:10 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
