1990 Iroc front brakes?
Old Nov 3, 2007 | 11:39 AM
Z28XTC's Avatar
I bought a crashed 1990 Iroc yesterday and I was wondering what sort of front brakes these have and if its worth swaping them into my 1992RS?
Old Nov 3, 2007 | 12:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 1990 Iroc front brakes?
take a look at them, they are either 1 piston iron calipers or more likely aluminum PBR 2 piston ones, the aluminum are better stock brakes, if the iroc has them and you 92 doesn't, swap them over if you want
Old Nov 3, 2007 | 12:21 PM
Z28XTC's Avatar
Thanks.
Old Nov 3, 2007 | 01:20 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You mean its more likely it will have the same 1-piston iron calipers that every other 82-92 thirdgen has. Only the 1LE's and the '92 B4C's have the 2-piston calipers, and they account for less than 1 percent of the total thirdgens.
Old Nov 3, 2007 | 04:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
It's possible someone swapped in PBR's. Check the following pic (if this is what's on the 90, you'll want them in the 92):
https://www.thirdgen.org/forums/atta...89-fbrake2.jpg
JamesC
Old Nov 4, 2007 | 03:16 AM
Z28XTC's Avatar
I checked them today and they are single piston.
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
