NEED HELP WITH UPGRADING MY 1991 Z28 TO LS1 BRAKES FRONT/BACK!!
Old Dec 6, 2007 | 12:21 AM
TURBO F100's Avatar
HI, i'm new here, how is everyone?
I want to convert the brakes on my 1991 camaro to ls1 brakes as well (i found info on the rear but not the front), I have the hole front suspension from a 1998 ls1 camaro( i had the rear to but someone stole the rearend from my tent were it was), So what i need help with is info on how and what is involved in doing the front and rear ls1 brake conversion on my 1991 camaro Z28 with rear drums.
Help with this would be great THANKS!!!!!!
Old Dec 7, 2007 | 07:49 AM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
Re: NEED HELP WITH UPGRADING MY 1991 Z28 TO LS1 BRAKES FRONT/BACK!!
It's super easy, there is a ton of info on here about it...just look around.
All you need to do is machine your stock front rotor down to just a hub, get some adapter brackets, modify your spindle a little, and away you go. The back is just about the same.
https://www.thirdgen.org/forums/faq-...s1-brakes.html
That has all the info you need...for the front anyway.
Old Dec 11, 2007 | 02:00 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You need hubs, modified spindles, and the conversion brackets along with all the brake parts from the donor car. You can't use any of the other parts from the car.
I have all the parts on hand, LMK if you need anything.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
