9 bolt disc swap ebrake cables
Old Dec 10, 2007 | 09:21 PM
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
swapping in a 9 bolt disc in place on my 10bolt drum rear. i need the 9 bolt ebrake cables. what are the part #'s? how long are each?
Old Dec 10, 2007 | 10:51 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: 9 bolt disc swap ebrake cables
9 bolt PBRs or the old iron calipers?
Ed
Old Dec 11, 2007 | 04:08 PM
Car: 91 rs
Engine: 305tbi
the rear is from an 88gta. i beleve i read pbr's only came on 89. so the iron ones
Old Dec 12, 2007 | 01:46 AM
ebmiller88's Avatar
OK. I'll get the numbers for ya.
Ed
Old Dec 12, 2007 | 04:10 PM
Car: 91 rs
Engine: 305tbi
thanks
Old Dec 13, 2007 | 02:39 AM
ebmiller88's Avatar
PM sent.
Ed
Old Dec 26, 2015 | 03:15 PM
FiVe KiLLZ's Avatar
From: Home of the world champion San Antonio Spurs. 210 baby!!!
Car: 1992 Z28 Convertible
Engine: LB9 - seeking sped density L98
Transmission: 700r4, have a t5 I am swapping
Axle/Gears: G92 3.23 third gen Borg warner
Originally Posted by ebmiller88
PM sent.
Ed
Hi Ed, I purchased a 88 iron caliper 9 bolt to place under my 92 z28, tossing the drum under it now. Can you PM this same info on the e-brake cables or offer the easiest way to accommodate this swap? Can I just remove the brackets from the donor car? Or is there something better or more mechanically correct to install for this combo?(pics are awesome if you have any). Assuming the lever from the handbrake to the tunnel brackets that James c issued on another post, seen here?
https://www.thirdgen.org/forums/attachments/brake-board/35153d1043846860-how-can-i-adjust-e-brake-adjuster.jpg
Also interested in your kits on fly and bye... So in the future it would be awesome to upgraded hear irons to the pbr kits you have, so any info that will help that swap on the future is also welcomed. However, I will need to swap this rear before I can grasp the brake swap so will have to run delco moraine until I stock cash up on the rear conversion. Any guidance now is greatly appreciated
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
timonator
Aug 13, 2015 11:27 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
