can someone identify this part
i have a 92 z28 with factory 4 wheel disc brakes, what is the rubber mounted weight attached to the e-brake cable bracket for, it is to the rear of the back brakes and is about 2 and a half inches in diameter, and about 1 and a half inches thick, can it be moved or removed, what does it do , is it OE? Please help, trying to get 11 inch wheels
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: can someone identify this part
i believe its just there to protect the line from chaffing on the panhard bar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I understand it to be some kind of vibration dampener as it's got a rubber insert around the large center bolt. I see no real point to it and I remove it from all rear calipers I use. Just added weight to me, feel free to pull it.
Ed
Ed
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I found this on Shoebox's page. Number 90. http://shbox.com/1/rr_disc_brake_assy.jpg
It says it is a dampener. I don't know what it does, but my car doesn't have them anymore. I took them off when I put my LCA relocation brackets on. My parking brake still works fine
They'll have no effect on the PB as mentioned above, they only bolt to the bracket and don't contact anything so they can go. Remove them and reinstall a 1" long 7/16" bolt and nut in their place.
Ed
Ed
HEY FELLAS, THANKS A LOT, THEY WILL BE GONE BEFORE DARK, I WASNT OVERLY CONCERNED ABOUT THE PB, JUST ON WHETHER OR NOT I COULD FIT 18X11 INCH WHEELS AROUND THEM, MERRY CHRISTMAS
LT1Formula
20
Nov 14, 2015 12:02 AM
Linson
Aug 21, 2015 02:12 PM
