e brake on 1le brakes
Old Feb 5, 2008 | 06:18 AM
z28phill's Avatar
Car: 86z28Hotckiss suspension 1LE Brakes
Engine: 355sbc
Transmission: t5 5speed
Axle/Gears: 373
ok car is a 86 z28 1le brakes all 4 when i pull the e brake the car can still move iv tryed adusting it but no go new pads calipers are good new cables?
Old Feb 6, 2008 | 05:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: e brake on 1le brakes
Free Travel adjustment?
https://www.thirdgen.org/forums/susp...ee+%252Btravel
JamesC
Old Feb 6, 2008 | 06:03 AM
z28phill's Avatar
Engine: 355sbc
Axle/Gears: 373
good info thanks bud
Old Jun 15, 2008 | 05:02 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
won't start another parking brake thread so....
I too have a '86 Z28 and swapped in everything from a '92 b4c/1le car.
This included rear end, parking brake cables and parking brake lever.
I have about an inch of slack between the equalizer and the rear cables. I'm stumped. I'm pretty sure the parking brake worked fine when I removed it from the donor '92. Does everything bolt to the same locations for all years? As in, are the clips where the cable snaps into place at the same location?
I've not tried to adjust the free travel as I'm not sure it will take a full 1". Correct me if I'm wrong
Old Jun 17, 2008 | 03:45 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Now that I've read your post fully, did you also replace your '86 parking brake cable along with the handle? The cables and handle are different. One solution is to reinstall your '86 parts and swap the e-brake cables over to the early style cables and away from the second design/late style '92 cables, this should clear it up. The free travel won't take up the 1" or so you have now.
Ed
Old Jun 18, 2008 | 10:09 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Thanks Ed,
I did swap everything over from the '92... It's essentially just an '86 shell and '86 dash with '92 everthing else. I started thinking that maybe I accidently put back on the 86 cables, but that's just not possible since the rear end that came out was drum and the 92 is disc.
As a temporary fix, I put on two alum. crimps at the ends of the cables. It's a road race car and I've heard enough stories and videos of brake failure on track that I decided to keep my e-brake in as a 'just in case'. Even if it only slows me down a few mph, that's a few mph softer of a hit.
Good idea about swapping back in the '86 handle and getting the first design cables. That'll be on my to do list after I get back from the races this weekend. Thanks again!
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
