factory brake help plz
Old Feb 12, 2008 | 12:05 AM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
well i have a 1988 camaro and the brakes act very wierd. sometimes they just dont work, the pedel wont move. other times the pedel will go all the way down, but not engage. other times the pedel is pressed and the brakes engage, but they dont seem to catch, as if wore or something. now these problems occor at all temps, at all speeds, anytime it wants basicly. there is no sign what so ever of damage or leaking, i have checked everything, it appears to be perfect, but it most deffently is not. whats wrong with them? and a side note it was a 2.8 with 700r4 when they where doing this, im bout to drop in a 350 with a t-5, so fixing the brakes is deffently high on my list of things to do
Old Feb 12, 2008 | 12:53 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: factory brake help plz
howdy there
hows the brake booster doing ?
when you shut off the car and pull the large vacuum hose off the booster is there alot of stored vacuum in it ?
any vacuum noise sound inside the car under the dash while running ?
if not then the problem has to be at a wheel, or in the master cyinder
car been sitting a long time not driven ?
pedal wont move makes me thing booster is bad, when they go bad it takes ALOT of force to get the pedal to move
it is rare for a GM booster to go bad, but they do, i have owned closer to 150 or 200 GM cars and only had one bad one, it was in an 83 caprice and the booster was already bad when i bought the car,
no vacuum noise sound however
booster was just plain dead non functioning
bought one off a junkyard car in which was actually a reman one by chance, off another caprice haha
for 40 bucks
check the booster for vacuum storage
after shutting it off it should have enough vacuum in it for at least two full pedal pumps
for safety reasons, in case the engine dies while driving, so you can safely bring the vehicle to a stop
this is how they are designed
for a reason
master cylinder failure is wayyyyyy more common
as well as brake hose failure
in which is a real possibility in your case
one may be internally colllapsed, i have had to replace many hoses due to this
a collapsed hose will either cause the brake on that hub to not work at all
or it will cause it to be stuck on/drag badly as if the caliper were stuck, but isnt actually due to the caliper being faulty
both occur
been here and had this happen on many different vehicles
if there is really no leaking or anything elsne the it has to be a component or hose failure
good luck
Old Feb 12, 2008 | 01:02 AM
DARKmj16's Avatar
Engine: 305 tbi
hmm all good ideas, how ever i checked most of them, there is NO leaks, nothn appears damage, how ever b4 i bought it i dont now how long it sat, 4 years i htink, then it became a daily driver, and its not at one wheel, its at all wheels at once.
umm there was no hissing noises....w8 there was one time for a little, but it was only one time.
umm i cant check the vac now bc well there is no motor in it, lol.
o and the 2 pedel pumps when the car is off, it ranges everytime when one of those things happens, i mean when the brakes messed up, the pumps would range from 1 up to 9, but the norm was 3 when the brakes worked correctly...
ill check the booster and master when i get a chance but right now im researching
Old Feb 12, 2008 | 04:56 PM
402 GTA's Avatar
Car: 86 GTA
Engine: 402 cbb
Transmission: th350
Axle/Gears: 9" 3.50
If the booster was bad it'd take a lot more to press the pedal but you'd still be able to "engage" the brakes. If it's sinking to the floor and the brakes are not engaging and you're sure theres no leaks it sounds like the master cylinder is internally bypassing. Still.. the check the wheel cylinder pistons and caliper pistons for leaks. Sometimes they only leak enough to make the shoes and springs look wet or pads.
Old Feb 12, 2008 | 05:03 PM
DARKmj16's Avatar
Engine: 305 tbi
hmm uk 402 gta u might b right, i remember that when i turned my rotors b4 that the springs looked wet, i didnt think anyhting of it, but thinking bout it, it was in the afternoon when i turned them and it didnt rain for a week, and there was no puddles i went tho. ill check those to, thank you for the help everyone.
but there still is a question, everything metioned seems to be wrong with my brakes, however why is the problems appear and disappear at will? and the problems are different at any given time when something happens. plus if any of these things was wrong how could i of drove it for so long and not have total brake faliure?
Old Mar 4, 2008 | 08:27 AM
thumper115's Avatar
Car: 1972 SS Nova, 1991 Camaro drag only
Engine: Stock 350, 355 w/12.5's
Transmission: 350 auto's
Axle/Gears: 3.55, 3.73
Sounds like you may have more than one problem. Sometimes like they have said the master cyl. bypasses. When they would not go all the way down is probably booster leaked down temporaily. It have even been a bad vacum line going to the booster.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
novaderrik
Aug 10, 2015 12:44 PM
