stock rotor size
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
Axle/Gears: 9inch 3.50 gear
stock rotor size
going to change my front rotors which are the 10.5. the parts store said they have optional hi-perf rotor which is 11-3/4 what did these come on? and i would assume thay use different calipers. any info would be helpful thks
Re: stock rotor size
Stock size is 10.5 dia on 99 44/100 % of 3rd gen cars the exception is 1LE & B4C cars haviving the 11.75 Dia. If your car is stock you CANNOT use the larger rotor size.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's a link that discusses both front and rear:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
Good luck.
JamesC
Good luck.
JamesC
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
