C6 Caliper Questions
Old Feb 23, 2008 | 09:29 PM
Troy 85Z's Avatar
Car: 85 Z
Engine: Edelbrock Injected 350
Axle/Gears: 3:42 LS1 Posi
I'm ready to pull the trigger on a Z51 brake setup but I have a question about the C6 Caliper. The C5 Z06 caliper on the Z51 rotor measures 7.75" from center of hub to outer rib. I would like to run the C6 caliper but I only have a little over 8" from center of hub to the rim and I noticed the C6 caliper has a little different reinforcement rib design. Does anybody have the measurement of the Z51 rotor with C6 caliper.
Old Feb 24, 2008 | 07:18 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: C6 Caliper Questions
The C5 and C6 calipers should be close enough to not make a big difference but here's a template for you, this should do it:
http://www.kore3.com/downloads/fitme...es/DOC0013.pdf
Ed
Old Feb 26, 2008 | 04:06 PM
86_Z28kid's Avatar
Car: 86 z28
Engine: 383 stroker over 30
Transmission: 700R4 B&M shiftkit chevy servo
Axle/Gears: 373 posi..
if ya wanna talk c5 brakes pm me... I have an 86 with the conversion on there and it fits nicely
sailtexas186548
Jan 19, 2016 12:21 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
Genopsyde
Nov 11, 2015 10:46 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
redmaroz
Aug 16, 2015 11:40 PM
