brake question
Old Feb 25, 2008 | 03:01 PM
sloviks88camaro's Avatar
Car: 1988 Camaro
Engine: 2.8l v6
Transmission: t5
brake question
my 88 rs has stock brakes all around and i want to upgrade.. right now im worried about the front b/c of what i read the only way to upgraded the rears is to do a 4th gen rear end swap for disk,rihgt? but is there anyone out there that makes a kit for our 3rd gens or like anything other rotors that fit? also i would like 4 piston calipers??? any info will help i just need to upgrade my brakes for more stoppin power...
Old Feb 25, 2008 | 03:55 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: brake question
I'm not sure what you read or where, but upgrading the fronts is relatively simply, so are the rears--and no, you don't have to swap in a fourthgen rear. Four-piston is probably overkill. If you have drums, Ed Miller makes a conversion kit.
Here's a link that will provide info about a front and rear upgrade (from 10.5" rotors and single-piston iron calipers to 11.7" with alum dual piston fronts and single piston rears (the 1LE set-up):
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Feb 25, 2008 | 09:21 PM
Car: 1988 Camaro
Engine: 2.8l v6
Transmission: t5
Re: brake question
thank you for the info.. i didnt know that 4 piston was alot the only thing on cars im not used to is brakes i try to stay away from them
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
