9 BOLT or 10 BOLT
Old Feb 28, 2008 | 10:47 PM
2badcams's Avatar
Car: a 91 rs convertible and a Iroc z convertible
Engine: 305 tbi, and 350 tpi
9 BOLT or 10 BOLT
i have a 10bolt drum on my 1989 IROC and want to upgrade to disc brakes. I picked up a 10bolt disc at the junkyard, thinking i could just swap parts. 2 weeks later i found a 9bolt disc at the junk yard. I also picked that up, and now i dont know which one to use? should i go 9 or 10? or keep the original and us EBMILLER brackets to do a swap only?
Old Feb 29, 2008 | 12:14 AM
Stephen's Avatar
Car: 87 GTA
Re: 9 BOLT or 10 BOLT
9 bolt is stronger, but harder to get parts for. Parts are out there, no doubt, just can't get everything for them anywhere.
Old Feb 29, 2008 | 04:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You can use Ed's kit on the drum rear or consider a disc upgrade to either the 9- or 10-bolt:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Feb 29, 2008 | 07:01 AM
85camarojunkie's Avatar
Car: Camaro coupe
I have a 9 bolt from my car i pulled out, its just laying in my back yard. Works great but i wanted to put a bigger gear in it, couldnt find jack for it. But its free for the taking, 3.27 limited slip. If your wanting parts for yours.
But 10 bolt is like the camaro there a dime a dozen. Jegs, Summit, you name it has the parts...
Old Feb 29, 2008 | 10:37 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
The 9 bolt biggest issue is its a cone type design, and very sensitive to care. If its not cared for it will wear out very quickly as the cones wear normally. Which is why most 9 bolts go, the cones have worn down and need to either be shimmed or replaced. I've got one, I like it, its strong, and you don't have to worry about axles falling out because the c-clip failed. It was worn when I got it though and will only kick the back end out in a left turn, in a right turn the inside tires spins badly.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
