squeeling brake and how do I adjust them
Old Mar 9, 2008 | 05:09 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
I just replaced the front bearings on both sides. Everything is back in the correct place and is tight. Now my diver side brake is pulling the car to that side especially in hard braking and will lockup if I'm not careful. Also the passenger side brake is squeeling, its gotten better over the past couple of days. It mostly does it when I am going from a stop when the brakes are cold and is intermitient wen I get up to speed. They stop squeeling when I push the brake pedal. The calipers, discs, and pads are all about a year old and have plenty of life in the pads. Brakes feel normal through the pedal. What could I do to fix the passenger side and adjust the brakes so that the driver side doesn't pull the car to the left. Stock disc brakes BTW.
Old Mar 9, 2008 | 05:26 PM
Re: squeeling brake and how do I adjust them
The correct question:
What could I do to fix the passenger side ... so that the driver side doesn't pull the car to the left
And the answer would be, change out the pass side rubber hose. But like all brake things, do the same thing to both sides.
Old Mar 9, 2008 | 05:52 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
That is on my list of things to do. I would have done them but I didn't have the money to buy new ones.
deracer
Apr 11, 2016 12:04 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Strick1
Sep 4, 2015 07:11 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
