Rear ls1 brake question
Old Mar 10, 2008 | 02:53 PM
CAMAROJOKESTER's Avatar
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
hi. i was trying to bolt up my rear calipers and i couldn't. I was wondering exactly where does the rear caliper bracket bolt up to? Is it betweent the ebrake assembly and the backing plate, i was wondering because i didnt try that. i tried to bolt it to the backside of the backing plate and it wont fit over the rotors, know way close to fitting.. is there as spacer betweent the backing plate and the ebrake.. please help .thanks
Old Mar 11, 2008 | 12:57 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: Rear ls1 brake question
The carriers will bolt onto the two holes in the LS1 backing plate. No offense but you do have all the right parts for the install? Something about the way you wrote that lead me to think you are either missing something or don't have everything you need...if the caliper won't slide over the rotor something's not right.
https://www.thirdgen.org/ls1reardisc
Ed
Old Mar 11, 2008 | 01:01 AM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
yes it will bolt up but I think I need to bolt it up with the carrier on the wheel side of the backing plate. I was trying to bolt it up on the back side of the plate and the caliper wouldn't clear the rotors. Is this correct?
Old Mar 18, 2008 | 10:41 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
thanks for the help eb.. i had corvette carriers so i went and got the ls1 rear carriers and it bolts up fine now.. thanks.. also i pmed you about the ebrake. please help..
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
