82 trans am brake line help
Old Mar 17, 2008 | 07:31 AM
tttbrian's Avatar
I have an 82 trans am and it has a hole in the brake line to the rear brakes. I want to replace the the whole brake line and was thinking about going stainless steel. Where can I get molded brake lines without getting raped on the price? Should I change out to braided hoses as well? Thanks!
Old Mar 17, 2008 | 07:00 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Re: 82 trans am brake line help
I have a set of factory brake lines in mint condition.
where are you located?
Old Mar 17, 2008 | 07:07 PM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
82's have standard brake line fittings so if you replace it with factory stuff it must be from a 82-83 f-body later stuff will not thread in or seal.
Old Mar 17, 2008 | 09:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Just buy 50' of 3/16" hard line from napa and bend it where you want it. Buy a handful of the clips to connect it to the chassis.
Then just cut and flare it as needed.
Old Mar 18, 2008 | 07:21 AM
tttbrian's Avatar
I live in Hamilton, Oh. Where are you located?
Old Mar 19, 2008 | 06:57 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might find what you want in the following links (Try classictube.com as well):
http://www.finelinesinc.com/
http://www.inlinetube.com/
JamesC
Old Mar 19, 2008 | 08:14 AM
tttbrian's Avatar
I ended up getting stainless steel brake lines through JC Whitney. They were about $40 cheaper. Thank for the help.
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
