SSBC adjustable propportional valve installation
Old Mar 13, 2008 | 01:09 PM
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
I surrender, I searched and nothing that I found was clear on this subject.
I want to install a SSBC propportional valve Summit part#SSB-A0730P on my 1989 GTA since my old stock valve is leaking thank's to the heat created by the former quad turbo kit I had previously installed, also I am planning on going with the LS1 brake swap real soon.
http://store.summitracing.com/partde...art=SSB-A0730P
I have several questions;
1) the stock valve has three(3) lines comming out from it, the SSBC has only two(2) outlet ports, what do I do?
2) The ports on the SSBC are listed as 1/8" npt's, both inlet and outlet, the stock ones are larger(dont know size), also what do I do or need?
3) Ths stock valve has sensor like switch or something that I believe is for the braking lights and the SSBC comes with its own switch which is a two pole. Again what do I do?
4) Has anyone done this before? Pics?
Please, any light on the path will be greatly appreciated!!
Old Mar 13, 2008 | 05:20 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: SSBC adjustable propportional valve installation
The block should replace yours fine, you will need to adapt the lines to the block however, the description I read said there are 5 ports.. 2 in, 2 for the front, 1 for the rear...check it out..
http://www.ssbrakes.com/products/det...l-In-One&year=
Frozer!!!
Jan 19, 2024 04:55 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
dcbsracing007
Aug 18, 2015 07:24 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
