Powder Coating Brake Caliper Question?????
Old Mar 15, 2008 | 12:54 PM
ChrisK's Avatar
Car: Turbo Trans Am/Buick Grand National
Engine: V6 3.8L TURBO
I want to powdercoat my from calipers. Is there somewhere that i can find out how to disassemble and reassemble the calipers? Is everything reuseable or do some sort of seals need to be replaced??
Any help would be great!
Thanks,
Chris
Old Mar 16, 2008 | 10:29 AM
ChrisK's Avatar
Re: Powder Coating Brake Caliper Question?????
Anyone????
Old Mar 16, 2008 | 11:48 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
everything has to be disassembled right to the caliper core, and after powder coating it needs to be rebuilt with a caliper rebuild kit which replaces all the seals.
Old Mar 16, 2008 | 01:43 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Thanks,
Chris
You need a compressed air source and one of those rubber tipped blow guns to blow the pistons out, and keep your fingers clear of the piston when it moves...they hurt when they come flying out. It takes around 90# to get the pistons out. Then clean them up good, media blast them if you can for better adhesion, and coat them. Make sure you mask of the piston bore and bleeder and banjo bolt holes, and MAKE SURE you mask off the area where the crush washer sits. If this small circle gets coating on it the washers wont' seal and you'll have a leak. If your seals are uncracked and flexible they can be reused but I still recommend new ones. Any questions, send me a PM.
Ed
Old Mar 16, 2008 | 03:55 PM
ChrisK's Avatar
Ed
Thanks for the Help and Tips!!!!!!
Chris
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Jan 19, 2016 12:21 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
