brake line overhaul
Old Mar 16, 2008 | 10:37 PM
82karr's Avatar
brake line overhaul
i have made several posts recently. i have yet another quandary. i want to replace my whole brake line assembly, and i want to stay with the current size lines i have on there. however, the lines are so rusted its hard to tell what size they exactly are. is there anywhere or does anyone know if it specifically calls for one size or can i just use whatever i want. any help would be great. thanks
-Jim
Old Mar 16, 2008 | 10:47 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: brake line overhaul
1/4" in the back? Not sure i keep reading some sizes are metric but not positive. My rear brake line that i'm tooling with right now may be metric but i very easily just put a 1/4" fitting over it and it's very tight. A private message to ebmiller might get you the results your looking for.
Old Mar 16, 2008 | 10:49 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I replaced the hard lines on a rear axle I swapped onto the car with some I ordered from Inline Tubes. They were prebent and came with the fittings and the "spring" tubing wrapped around it, just like stock. In order to not get a complete car set, I had to call and specify what I needed.
www.inlinetube.com
Old Mar 17, 2008 | 12:59 AM
dayton's Z's Avatar
Car: 85z-28
Engine: gm goodwrench 350
Transmission: t-5
Axle/Gears: stock, 3.08 one wheel peel!
+1 on inline tubes, take out the old put in the new. they are a little pricey but i think worth the extra cost. also i went stainless steel, if u buy all the lines in their kit its an extra $20 over the oem, higher tensile strength too!
Old Mar 17, 2008 | 06:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Should you wish to purchase pre-bent, check the following sites:
http://www.finelinesinc.com/
http://www.classictube.com/
http://www.inlinetube.com/
JamesC
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
