rear brake (will this work)?
Old Apr 7, 2008 | 04:39 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Check out these pics here. The first is a pic of my new rear. The next (2) are the backing plates off another rear I have. They are both 10 bolts. The mounting locations on the rear look the same, so I know I can swap them over. Now my question is... am I limited to using the iron calipers with these backing plates??... or can I use other disks...(pbr's from a 92 camaro, 93-97 pbr's??) Thanks.
Attached Thumbnails rear brake (will this work)?-rear-axle.jpg   rear brake (will this work)?-backingplate1.jpg   rear brake (will this work)?-backingplate2.jpg
Old Apr 8, 2008 | 03:32 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: rear brake (will this work)?
Those plates are for the iron calipers, PBR calipers will not bolt to them. If you need PBR plates let me know.
Ed
Old Apr 8, 2008 | 05:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A pic of the 10-bolt PBR backing plate:
https://www.thirdgen.org/forums/atta...s-89-shims.jpg
JamesC
Old Apr 8, 2008 | 05:03 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
So if I get pbr backing plates like James C has in his picture I can go and buy pbr brakes and rotors from a 93-97 camaro and bolt them on??
Old Apr 8, 2008 | 05:49 PM
JamesC's Avatar
Check the following link:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Apr 9, 2008 | 12:31 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Ok so according to ur article I found these at my local Kragens..which is the same part number as u mentioned from Advanced Auto. They are from a 1992camaro.
http://www.partsamerica.com/productd...e=5003&PTSet=A
Ive also found the rotors and hoses from car quest as u mentioned the part numbers.
Now all I need is the backing plates and the shims...who can help me on this??...ive emailed ebmiller and i bet hes busy.
Old Apr 9, 2008 | 12:39 PM
JamesC's Avatar
Below, but pricey:
http://www.andyz28.com/catalog.htm
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
kyleb24
Aug 15, 2015 08:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
