Brake pad recommendations for pbr and other Q's
Old Apr 19, 2008 | 01:34 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Just did a swap from drums to Lt1 discs (PBR). What brake pads should I get? Seems a lot of guys like the Bendix, but I cant find them for this caliper.
The rotors that came with them have 5/8 holes for the studs, my studs are 1/2. Kinda sloppy. Is this bad?
Also, will I need an adjustable p-valve? Is there one that doesnt require me to make new flares?
Old Apr 20, 2008 | 09:19 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: Brake pad recommendations for pbr and other Q's
I will recommend Hawk HPS pads without question.
On the studs, they need to be tight. If they're loose you'll have problems.
You don't need an adjustable per se, some guys like to have them. I would personally recommend the factory disc/disc prop and be done with it.
Ed
Old Apr 20, 2008 | 10:21 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Ed
I just put some of these on my car today. These groan allot less than the factory pads that were on there(low milage car that sits allot). They also actually stop the car without having to stand on the pedal.
Old Apr 20, 2008 | 10:38 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Good thanks. The rotor has about an 1/8 inch of slop in it. Wonder why the holes are so big. I'll use them for a little while, the car doesnt see much backing up.
Old Nov 15, 2008 | 08:06 PM
bigals87z28's Avatar
Car: Check The Sig
The holes in the rotors arent going to be EXACTLY the same size as the studs. They are designed to be a little loose.
Wouldnt worry about that. And yes, suggest HPS pads. Not HP+ or anything else.
Old Nov 16, 2008 | 01:41 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
The holes are a little bigger than I'd like, but I havent noticed any sliding. The HPS pads are working great. Car brakes very well even with 9" of vacuum.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
