I have completed the drum to disc conversion. Put in a borg warner 9 with the old style calipers(my first mistake after reading post history) I bought it used and rusty with master cyl and prop valve. I put rebuilt calipers on and new pads installed the master etc. Now I have to pump it up to get slowed down. I bled them numerous times and made sure the E brake is adusted and holds. Brake stand will melt down the rears, which is cool but not comforting knowing that car will carry wife and son. Did I get the wrong prop valve...or should i bench bleed master cyl??or is this normal for the old cast rears??? I know the ultimate answer is alum style calipers but I already have bout 400 bucks in this mistake already!
86 Z
crappy borg warner 9 ....didnt do my research
75 4bolt 355
86 Z
75 4bolt 355
Was a new Master Cylinder installed or the old one?
the rearend was bought with the master cyl and prop valve used package deal. I think ill go with a adj prop valve in the rear line and a blank tee in front???
Quote:
The front brakes do the majority of the work when stopping, so I don't think you put all the blame on the rear calipers. When you say the Master Cylinder you currently have is used — how used? Do you now how long it was sitting around before you bough it?Originally Posted by wifes86z
the rearend was bought with the master cyl and prop valve used package deal. I think ill go with a adj prop valve in the rear line and a blank tee in front??? If anything, you might want to start with a new Master Cylinder.
Did you bench bleed the master/ new valve?
no, I will bleed the original master install it and see how it turns out.....Thank you
vortec350s10
close
Ahh the joys of old style discs! I remember not being able to put my old car in park on ice because even while stopped the rears would keep spinning at idle! I remember reading about those calipers too in various posts , and I think I remember some even saying that the rebuilt ones were a lot of the times junk too. You probably spent a bunch of money on new ones, but I'd consider just doing an LS1 swap. I bought the whole setup for $150 on ebay, and it was relativley easy. At least then you have a proven design without the stupid e-brake-built-in calipers. Just my two cents.
