Front aluminum dual piston swap?????
is it possible to swap out the iron single piston calipers to the nice aluminum dual piston calipers and keep the 10.5 brake rotors or would u have to switch to 12" 1le rotors? also i have the 10.5" disc brakes in front with 12" disc brakes in the rear....are the rears considered 1le parts or is it in a category but itself? any help would be appreciated...thanks guys!!!!
Last edited by tacozzz90; Apr 25, 2008 at 12:22 AM. Reason: added more to question
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Front aluminum dual piston swap?????
http://web.archive.org/web/200605221.../1LEbrake.html
Spohn sells the kit and "may" modify the spindles (but it's something you can do yourself--I did and I'm no rocket scientist).
The rears are often called 1LE, but they're standard on all four-wheel disc cars from 89-92.
JamesC
