Spohn Big Brake Kit question
Old Jan 16, 2004 | 03:10 AM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
Does anyone know if the kit will fit under the Ronal Firehawk rims?
Old Jan 17, 2004 | 07:42 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
which of his kits are you looking at? the 1le or the wilwood?
chances are it will fit, but i cannot confirm that, i have heard that the ronals don't have as much room under them as most of the other 17" wheels do, but i would image they have as much room as the iroc wheels do. but once again, you would have to get measurements of both the ronals, and irocs, to confirm if they will fit.
Old Jan 17, 2004 | 11:16 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My friend has the Baer Track front and rear brakes on his 82 with teh Ronals. I think his rotors are 12" up front, not sure of the rear, but they are smaller than 12".
Old Jan 17, 2004 | 01:11 PM
YenkoZ28's Avatar
Car: 1991 Z28
Yeah I'm talking about the 13" wilwood kit.
Old Jan 17, 2004 | 01:20 PM
Zepher's Avatar
Why don't you order them, send them to me and we'll put them on my friends car and see if they fit. Then we'll send them back to you.
Old Jan 17, 2004 | 01:51 PM
YenkoZ28's Avatar
Car: 1991 Z28
I already have a set of firehawk rims on my car, I'm just looking into what my options are for aftermarket brake setups that will fit under them.
Old Jan 17, 2004 | 01:59 PM
Dewey316's Avatar
Car: 1990 Camaro RS
i doubt anyone has test fit them with those wheels, i would find a iroc wheels, which we all know works with them, and compare them.
Old Jan 17, 2004 | 02:07 PM
YenkoZ28's Avatar
Car: 1991 Z28
Does anyone know how far out the 4 piston caliper sticks out from the rim mounting surface of the rotor? This would help me figure out if they will in fact clear the rim.
Old Jan 17, 2004 | 08:14 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
There was a post about this a few months ago - I believe the 13" Baer 2 pot will not fit the hawk rims but the 12" 2 pot Baer set up will fit.
I think the 13" 4 pot wilwood set up that Spohn sells will fit the hawk rims because they are open at the top of the caliper for cooling.
Old Jan 17, 2004 | 11:41 PM
YenkoZ28's Avatar
Car: 1991 Z28
I'm not worried about diameter clearance with the firehawk rims. I'm worried about clearance with the backside of the spokes hitting the caliper.
Old Dec 10, 2004 | 05:17 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Anyone one ever get an answer to this.
I have ronals as well and it seems the C5 conversion won't work with them.
Old Dec 10, 2004 | 11:56 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I have all the C5 brackets but no caliper so I haven't tried to see if they will clear. Where is the interference?
Old Dec 11, 2004 | 09:43 AM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
I've been going through a lot of the old posts on brake upgrades.
Someone said Spohn confirmed by email that his Wilwood kit will fit the Ronals. If I go that route I'll just call up Spohn's tech dept. and find out for sure.
With respect to the C5s and Ronals, there was some mention in an old post about the caliper not clearing the back of the spokes. Obviously have to follow up on that one.
I think the C5s would be more than enough for what I do even if there's some tapering. I just run at lap days so it's not being raced really hard - out for 20 minutes at a time usually - although I'd prefer to have more brakes than I need.
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
Exactly what measurements do you require? I'm running the 13" wilwod kit with iroc rims.
Si.
Old Jan 7, 2005 | 04:28 PM
92RSZ's Avatar
Car: 91 Z-28
Engine: 420 sbc
Axle/Gears: 12 bolt/4.10 gears
the wilwood kit will fit. Ive got the firehawk wheels on my car and the inside diameter is larger than that of the stock z-28 wheels. If they fit the stock wheels, theyll fit the firehawks.
Old Jan 9, 2005 | 10:35 PM
JPrevost's Avatar
Car: 91 Red Sled
I have racing rims similar to the ronals where the center section is nearly straight up from the hub mounting surface. It is less than an inch of space and that goes away as it goes up to the shell (real 3-piece wheel).
So I'm going to say no, it won't fit those wheels because of the center section spacing. You can fit a floating caliper in there with 13" rotors but the wilwood 4 pots are too thick. They SHOULD fit the 91-92 RS/z28 wheels, look at their center section offset and it should be clear why.
You might be able to fit LS1 rotors (12") with the wilwoods.
If you could take a picture of the inside of the rim I could probably tell you.
I have c5 12.75" rotors sitting here with wilwoods but they don't fit under my current wheels . Bracket is all made and everything is just waiting new wheels and spacers.
Old Jan 9, 2005 | 11:04 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
You might be right about that. Look on the Spohn site where it shows the different rims which fit this kit. All of them have the spokes near the outer edge of the rim. Here's a shot of my car showing how far the spokes are set into the rim on the Ronals.
Old Jan 13, 2005 | 04:48 AM
JPrevost's Avatar
Car: 91 Red Sled
Yeah, that looks too tight. I hate giving up on the large brakes for the appearance of my wheels but my tires were too new and I still like that my wheels were a limited production just like the Ronals.
There is plenty of room for the caliper and rotor if you get a custom hats made for a 2-piece rotor setup. This of course would require a different mounting bracket.
Old Jan 13, 2005 | 11:37 AM
YenkoZ28's Avatar
Car: 1991 Z28
I ended up using the 1LE kit from Spohn, which fit great and allowed me to toss the front spacers on the ronal rims. For the rear I went with the bear rear disc brake kit. All I can say is my car stops nothing like it used too.
Old Apr 20, 2008 | 03:25 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Re: Spohn Big Brake Kit question
So will these brakes definatley not fit the Ronal wheels?
Old Apr 20, 2008 | 05:04 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
I think someone at nethirdgen.org knows someone who got a C5 setup to fit with Ronals and posted pictures to prove it..lol
Old Apr 20, 2008 | 09:10 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I test fit C5s on the Ronal wheels and they were a no-go. Now the 13" Wilwood kit using the FSL calipers may be a different story.
Ed
Old Apr 21, 2008 | 03:33 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Ed,
Thanks for the reply. I've sent you a couple of PMs the last couple of months, but I know you are busy.
What kits do you do that fit the Ronals? Will the Wilwood setup that fits behind the GTA crosslace wheels work? I saw the setup that Gordon received a couple of weeks ago and want a brake upgrade myself but want one that will fit under a set of future Ronals.
Thanks,
Robert
Old Apr 21, 2008 | 06:15 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Ed
Yeah, it was C4HD not C5.
I never heard how it worked out but apparently it was a pretty tight fit.
Old Apr 21, 2008 | 10:43 PM
ebmiller88's Avatar
Ed,
Thanks,
Robert
Yes it will, I'll test it again to be sure once I get one together. I am still cleaning up PMs but I'll get to you quickly, pardon the delay. Gordon's kit was fun to do.
Spohn no longer offers this kit. AFAIK, I'm the only one.
Ed
Old Apr 22, 2008 | 10:22 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
The Ronals Firehawks WILL clear ed miller 13 inch willwood kit. The wheels marked front WILL CLEAR the ones marked rear require about an 1/8 inch spacer.
I know because that is what I run. I do not know about the spohn kit.
Old Apr 23, 2008 | 10:29 PM
ebmiller88's Avatar
Thank you Cash, nothing like first hand knowledge and input.
Ed
Old Apr 24, 2008 | 12:59 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
What rotors come with that kit? 13" Corvette HD?
Cheers
Old Apr 24, 2008 | 07:25 PM
ebmiller88's Avatar
Yes, 13" HDs.
Old Apr 25, 2008 | 08:07 AM
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
Yes, 13" HDs.
Hey Eb,
I'd PM'd you a while ago, I need the LS1 brake swap brakets, new longer caliper brake lines and the spindle modification.
Ed
Old Apr 25, 2008 | 08:53 PM
ebmiller88's Avatar
I'll check and get back to you.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
red90IROCls1
Aug 25, 2015 06:56 AM
redmaroz
Aug 16, 2015 11:40 PM
SiCkRs
Aug 8, 2015 08:12 AM
