rotors/drums
Old May 4, 2008 | 11:52 AM
built's Avatar
Car: 82 TA
rotors/drums
Does anyone know the thickness a rotor and drum can be before it's trash.
I can save money and have them turned but I can save myself time if i know when i take them off if they can be turned at all.
Old May 4, 2008 | 12:10 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: rotors/drums
Don't know about the rotors, but the drums should have a max diameter stamped on the outer rim.
Old May 4, 2008 | 12:24 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: rotors/drums
Take them to the machine shop/parts store. They will measure them and let you know if they can be turned.
If the "min thick" isn't cast into the rotor, they have books to tell them that information.
Old May 5, 2008 | 03:06 PM
87tpi350,6spd's Avatar
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Re: rotors/drums
0.98 is min refinish thinest after resurfacing spec for the front
Old May 6, 2008 | 03:53 PM
built's Avatar
Car: 82 TA
Re: rotors/drums
Old May 13, 2008 | 07:35 PM
wedjim's Avatar
Re: rotors/drums
Stock 3rd gen Camaro, same as 2wd S-10, early Malibu, etc.....965 is discard and .980 is the least it should be machined down to.
There is a way to tell without a micrometer though, if needed in a pinch...Just look at the inner vents, which are just less then half the total thickness of a new rotor and compare the outside, or pad surfaces to each other. They should look like they are about .250 or 1/4 inch(approximately) with the naked eye and have a small 45 degree cut on the outer edges if they have not been turned down excessively yet.
The vents are about .500, the pad friction surfaces are about .270, for a new rotor thickness of 1.040. Varies from manufacturer though, so that is where about comes in....
...Jim
W.E.D.
Old May 13, 2008 | 09:07 PM
Al Hasse's Avatar
Re: rotors/drums
I have a pair in the garage I acquired from the junkyard with intentions of turning them down into hubs. One has minimum thickness stamped on the face of the hub, the other is stamped on the back side of the hub. Both indicate 24.28mm.
