messed up brake problem...
Old May 4, 2008 | 09:57 PM
hectre13's Avatar
Car: 1984 15th Anv. T/A
Engine: HO 5.0
Transmission: TH700r4
Axle/Gears: not sure yet!
ok, heres my issue... i got my trans installed.. and was testing it out and the brakes seemed to be working fine...
after running the car for a little bit, putting it in and out of gear and moving it back and forth, it started leaking brake fluid, i thought it was leaking from one of the calipers, so i replaced both calipers,
I re-bled the brakes, they hold pressure fine when the car is off, and they hold pressure fine at idle, or so it would seem, but after driving the car for a few, it starts leaking again. the weird thing is, is that its dripping from the cover that bolts on the trans to cover the torque converter.
it will only leak after driving the car for a few, it doesnt seem to leak otherwise.
any ideas what my problem is? i was thinking if it were a bad brake line, that it would leak everytime i pressed the pedal.
thanks,
-jeremy
Old May 4, 2008 | 10:03 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: messed up brake problem...
i believe there is a valve on/near the transmission that opens when you hit the brakes to shift from park-drive gears. I heard about those going on alot of s10's and leaking only after being driven. But im not entirely shure. can someone back me up on this?
Old May 6, 2008 | 07:33 AM
hectre13's Avatar
Engine: HO 5.0
anybody else have any ideas?
Old May 6, 2008 | 08:32 AM
hectre13's Avatar
Engine: HO 5.0
how about this? is it a possibility that the prop valve is the cause? if so.. where is the prop valve located?
dbrochard
Oct 3, 2015 12:43 PM
dbrochard
Sep 19, 2015 08:13 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
