ls1 fronts
Old May 5, 2008 | 03:49 PM
wht96's Avatar
ls1 fronts
I'm Looking for the write up on this conversion can anyone lead me in the right direction. I thought it was in the FAQ but i didn't see it. any help would be awsome. Thanx
Old May 5, 2008 | 03:56 PM
Stephen's Avatar
Car: 87 GTA
Re: ls1 fronts
Are you referring to a sheetmetal external conversion? LS1 nose on a 3rd gen?
Old May 5, 2008 | 04:44 PM
wht96's Avatar
Re: ls1 fronts
im sorry i should have been more specific. i mean the ls1 front brake conversion. thanks
Old May 6, 2008 | 11:15 AM
Stephen's Avatar
Car: 87 GTA
Re: ls1 fronts
Are you looking to do it 110% at home? bigbrakeupgrade.com sells ful bolt on kits, or just the pieces you need, if you can't do EVERYTHING, like getting your spindles turned down.
Old May 7, 2008 | 10:31 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: ls1 fronts
Here you go:
https://www.thirdgen.org/forums/faq-...s1-brakes.html
LMK if you need anything, I'm glad to help out. Get your best price with ceramic pads and braided lines and then get with me.
Thanks!
Ed
Old May 8, 2008 | 03:30 PM
wht96's Avatar
Re: ls1 fronts
awsome, i was looking in the total wrong direction lol. Here's my deal I'm putting on an lt1 rear disc setup and then the ls1 setup. from what i understand all i would need are calipers, carriers, your little caliper mount bracket. some bolts and (this is where i get confused) a rotor to be used as a hub/spacer for under/isnide the ls1 style rotor?
my concerne is does this "hub" have to be a exact tight fit? like maybe differant brands of rotors have slightly differant tolarances and say one could have a slightly bigger opening and one could be smaller???
anyway i would imagine u offer kits. so how much for the complete kit? calipers to rotors, and how much is just the brackets, and how much for the hubs. any help would be awsome.
Old May 8, 2008 | 07:51 PM
ebmiller88's Avatar
Re: ls1 fronts
Right, the brakes and then all the custom parts you'll need to finish it up, along with the spindle mods. I also recommend installing braided lines to finish your upgrade but it's not necessary.
The LS1 hubs is a bit different than C4 and C5 hubs in that it must sit inside the rotor hat but it still needs to be as large as possible to keep as much strength as possible, 5.9" is a good outside diameter for the LS1 hub.
I'll PM you with more info on the setup.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
