rear adjust
Old May 7, 2008 | 04:35 AM
built's Avatar
Car: 82 TA
rear adjust
how tight do i make the rear drum when adjusting the rear brakes.
Old May 7, 2008 | 10:35 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: rear adjust
They adjust themselves, just keep pulling the cable up and down to adjust the tension.
Ed
Old May 8, 2008 | 06:59 PM
built's Avatar
Car: 82 TA
Re: rear adjust on a 82 TA
you mean the parking brake?
I did some more research and i think if i just adjust the start wheel till the drum has a slight drag i should be ok, sound right to you?
Also today while replacing the front pads I found a worn line so that needs replaced but that means bleeding the brakes and the bleeder valves are rusted on big time and i soaked them in wd40 but it still would not come loose, I tried vise grips but it just rounded of the shoulders some, Now what can i do to get them out or loose or bleed the brakes ?
Old May 13, 2008 | 06:52 PM
topless89's Avatar
Car: 89 RS Convertible
Engine: 305 tbi
Transmission: 700R4,B&M friction,Transgo shiftkit
Axle/Gears: 2.73 LSD
Re: rear adjust
a bolt-out might get them off, but you'll have to replace them.
Old May 13, 2008 | 11:19 PM
built's Avatar
Car: 82 TA
Re: rear adjust
youre right ,i just replaced them both.
got everythign back together and it's better than ever.thanks for the replys.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
86White_T/A305
Aug 17, 2015 12:16 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
