rear abutment bracket replacement
Old May 9, 2008 | 11:44 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
I slid sideways into a curb and broke a bunch of parts, and now I am trying to get things put back together. Searching came up empty on my proiblem so here it is. First I have calipers from a 93-97. I twisted the abutment bracket and snapped the guide pin. I am having one hell of a time getting the abutment bracket off of the caliper. It appears that I need to get the emergency brake spring off in order to seperate the two parts. What is the trick to removing the spring? If I buy a new caliper will it have the bracket attached? I need to get my car back together soon, HELP.
Old May 10, 2008 | 12:25 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: rear abutment bracket replacement
You must get the spring out to get the lower bracket bolt off or loose. Use a standard screwdriver and pry the spring up off the e-brake lever through the cable mounting bracket and remove it. To reinstall it, I use a pair of pliers on the spring and slowly move it back where it needs to be. It's not easy just take your time.
Ed
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
jahblah
Aug 12, 2015 05:54 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
