Pads too Tight?
Old May 10, 2008 | 09:09 PM
sh00k's Avatar
Car: 86 Trans Am
Engine: 5.0 305 4bbl
Transmission: 5spd
Pads too Tight?
Hey guys, I have done brakes before on non-thirdgens. I mostly grabbed the economy pads and tossed them on. This time, on my 86 trans am (4 wheel disk), I bought some mid/premium pads. After retracting the puck as far as I could get it with a c-clamp and retracting those bushing fully, I was able to barely squeeze on the calipers.
Normally I find the brakes move or have some freeplay to them at this point and I need to pump the brake pedal to set them and such. However, the capilers barely fit on and the pads I bought are resting right against the rotors, impeding their travel (atleast by the force of my hand). I don’t want to test them out and drive the car just in case I run into a situation where I need to take them off and will never be able to. My question is, is this normal to have pads this tight against the rotor on a thirdgen with better pads?
My car is still jacked up from when I put the pads on, I haven’t done anything, and I assume the puck cannot be retracted any further (so I don’t think it could be a flex problem).
Old May 10, 2008 | 09:15 PM
kcb37's Avatar
Re: Pads too Tight?
Take the bolts out of the caliper you loosened to take them off. (slide bolts)
Then clean them up and grease them.
Had a 91 Corsica that was taken to a brake shop, the guy there sanded the pads down to make them fit.
I beat the old slide pins out of the calipers, then put on new slide pins and calipers. Worked just fine.
Old May 11, 2008 | 08:51 AM
sh00k's Avatar
Car: 86 Trans Am
Transmission: 5spd
Re: Pads too Tight?
Alright, so I guess I will have to be sanding down the pads then. Thanks for the help.
Old May 11, 2008 | 06:16 PM
jwdomino's Avatar
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
Re: Pads too Tight?
rears? they need to be "turned" in with a caliper tool.not forced witha c-clamp
Old May 11, 2008 | 10:17 PM
sh00k's Avatar
Car: 86 Trans Am
Transmission: 5spd
Re: Pads too Tight?
I am working on the fronts.
Ed1LE
Sep 30, 2018 09:14 AM
Vintageracer
Sep 24, 2017 12:34 PM
86IROC112
Nov 7, 2015 06:50 AM
loud91rs
Oct 5, 2015 10:05 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
