Rear Braided Line Install Question
Old May 17, 2008 | 02:13 PM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
I bought Russell's braided brake line kit, and I noticed rear brake line (the single one that breaks off into two lines right at the axle) was meant for an lines. Meaning that a male flare was needed to complete the seal on the hard lines when connected inside the T-block, but hard lines have a female flare. I know I should get two an3 to hard line adapters to make everything work properly. But my question is, who just screwed the hard lines straight into the T block? Any leak problems?
Old May 25, 2008 | 01:17 PM
smgseanmicheal's Avatar
Car: 86 z28
Engine: 305ish
Transmission: 700r4-kickdown cable
Axle/Gears: ill figure out when i pull it apart
Re: Rear Braided Line Install Question
i have no idea ive got my 86 z28 jacked up right now i touched my brake line where it was leaking and it broke in half so im gonna need some info on how long the line is and stuff
Old May 26, 2008 | 11:48 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Did you buy the correct lines for your car? This should not be an issue.
Ed
Old May 26, 2008 | 01:39 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
The kit is for a rear drum brake thirdgen, came with 3 lines, the 2 fronts and the single rear with the Y block. All the lengths are correct and everything else is fine except for this flaring issue. I figure most people who buy this kit just jam the 2 together not looking or not realizing they need an adaptor.
Old May 26, 2008 | 02:06 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Did you call them. They have a tech line, I found the # on the internet. Russell is a division of Eldebrock. I would call them, maybe the wrong fitting was put on the line?
Old May 26, 2008 | 02:35 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
I dont know about the Russel lines, but the Earls lines fit like a champ.
Old May 26, 2008 | 02:39 PM
ebmiller88's Avatar
I reread your first post. You bought new axle hard lines, right?
There are two basic brake line flare types. One is a Metric bubble flare, the other is an inverted flare. Pics of both are at the bottom of this page.
http://fedhillusa.net/aboutus.aspx
Your third gen hard lines should have the Metric bubble flare to fit inside the "T" block, not the AN style you think. Some 4th gen line fittings still use the inverted flare but not our cars. Make sure you match the right styles or you will have leaks.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
