need help with my brakes
Car: 92camaro,86 camaro
Engine: 355
my brake pedal will not come back up after is push down you have to pull it back up by hand , i check all lines and look like is all in good condition. does any one know what is going on? this is the last thing i got left on my car build up will like to get it on track or lest the road.
Car: 1987 Camaro Z28 LG4 4bbl
Engine: 305 LG4
Transmission: Borg T-5
Axle/Gears: 3.73 open
Re: need help with my brakes
I'm no expert, but first off. Double check to make sure you have plenty of fluid and no leaks anywhere, look everywhere! Really sound like a new Master cylinder may be needed. Do the brakes grab when pushed? If so, do they release when the pedal is pulled up? Maybe binding in the peddle linkage? Thats just my two cents. Others may have other ideas. Hope this helps.
Engine: 355
i figure it out i had new lines so that wasnt the problem . the problem was the brake booster was bad! pain in *** to get swap!
dbrochard
Sep 19, 2015 08:13 PM
