something binding in brake system?
Old Jul 7, 2008 | 06:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
never noticed this before, not sure if its a new problem or something i just didnt notice because i was still breaking in the car and not panic braking, but i only have about 1" of pedal travel, then the pedal just stops dead, solid. There should be a lot more travel, no? i cant even lock the brakes. The car stops pretty well regardless but something is wrong, any ideas?
i checked the pedal for binding, nothing there.
question, i unbolt the master cylinder and push the brake pedal, will it damage anything, seals ect? i want to try to trace back to where the problem is, its almost like the master is binding up? its a ls1 master and a stock booster.
Old Jul 11, 2008 | 08:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: something binding in brake system?
well, thanks for the help guys
i have it all figured out, i was not making enough vacuum to use the brakes. I installed a vacuum reserve canister and its all good.
-Phil
Fronzizzle
Mar 18, 2019 08:29 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
zayne0
Aug 24, 2015 07:22 PM
overdriv
Aug 20, 2015 03:52 PM
