9 bolt e-brake system
Old Jul 14, 2008 | 10:02 AM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Alright, i have oredered cable after cable for my car and cannot seem to get this right, Every single one is either too long, or has the wrong hook ups. I have finally managed to find a set for the rear end, a 1987 9 bolt out of a formula at napa, ( i know i should have tried there first) The problem is, one side is 35$ and the other is 25$, the guy says they are different lengths. Now im asking if anyone who has a 9 bolt, preferably one without the PBR brakes could post up a picture of under their car with the whole system, im hopping the front cable will work from my 91, but i have never seen the system on a car before, i only know what i have so before i order another set of cables, id like to know what im supposed to be getting.
Damn state inspections lol.
Thanks for any help.
Old Jul 15, 2008 | 03:07 PM
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
Re: 9 bolt e-brake system
your car has the iron calipers on the rear like mine (it has a 9 bolt also..)? on my car the passenger side brake caliper points twoards the front and the drivers to the rear. so that would explain why there are 2 different lengths. it should work, i wouldnt see why not.
Old Jul 15, 2008 | 10:44 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Holy crap, I feel for ya pal.
I wen through this same hell with my 9 bolt and PBR's and ended up with CUSTOM MADE rear brake cables that were installed incorrectly and therefore no good. The cables were riding on my drive shaft so we ended up zip tying them to the frame. I am one yank of the e-brake handle away from them being on the drive shaft again.
Anyway, check out these threads:
https://www.thirdgen.org/forums/brak...ghlight=ebrake
There are some part numbers in there that I am sure are the right ones THAT DO NOT REQUIRE MODIFICATION but I could be wrong about that.
Good luck!!
Here's another:
https://www.thirdgen.org/forums/brak...er-ebrake.html
Last edited by Cadillac; Jul 15, 2008 at 10:56 PM. Reason: added stuff, editted stuff
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
bdads
Aug 24, 2015 06:01 PM
theurge
Aug 21, 2015 12:46 PM
