pic of a caliper...what kind?
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
I have a 10 bolt with aluminum calipers with what i thought where 1le calipers(fins run from front to back)... I bought a 10 bolt alum. caliper conversion kit Ill be selling and the guy told me it was a 1le kit but the fins stop in the middle. What kind of caliper is it? heres the pic.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: pic of a caliper...what kind?
Plain old boring aluminum PBR calipers, just like were on every car with rear disc brakes from 89+, regardless whether they had 1LE fronts or not.
Car: 87 GTA
Engine: 385 sbc
Is there any difference between these and mine? Heres a pic of mine
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
whats up with those rotors did you paint them?
Car: 87 GTA
Engine: 385 sbc
yeah,,, they need to be resurfaced and I was going to paint the hub section so I saved some time not masking it off....... Anyone know for sure why the top caliper doesnt have the fins running the entire length. I was told the entire kit was bought from bear brakes
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The 89-92 (so-called 1LE) and 93-97 (LT1) are essentially the same. I agree with Daz: Someone took a grinder to them to clearance the wheels.
JamesC
JamesC
Car: 87 GTA
Engine: 385 sbc
no,, I checked for any type of sanding or grinding swirls and there are none, plus the ridges would show if they were ground at the ends. Also the emergency brake cable bracket has the fourth gen bolt which is totally different from the 3rd gen .... everything looks the exact same except for the fins and that long bolt....... also I double checked parts...
http://www.autozone.com/R,674384/veh...ductDetail.htm
http://www.autozone.com/R,1262445/ve...ductDetail.htm
JamesC
Car: 87 GTA
Engine: 385 sbc
No they dont,,, the 1996 fins stop in the middle of the caliper just like the ones I just bought,,, sorry I wasnt clear about the "long bolt" I meant the bolt on the emergency brake bracket thats like 2 1/2" long,,, thirdgen brackets dont have that bolt
JamesC
Car: 87 GTA
Engine: 385 sbc
I think so, not totally sure but from what Ive read thats the only difference between the two.
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I noticed this when I replaced my left rear caliper. The one I got from Napa doesn't have the full-length fins, while the one that came with the rear end (bought from Ed Miller) does. Mismatched things upset me.
Car: 1991 RS Camaro
Wonder why the ones on the rear I got both had the long fins then... I know it's a 4th gen rear because of the width of the rear end...my ZR1s fit, lol.
Car: 87 GTA
Engine: 385 sbc
there really the same caliper minus the fins and the damper on the lt1 caliper....... totally interchangeable..... prev owner prob had 1 go bad and replaced it with a 3rd gen caliper. Wont make any difference except driving you nuts..lol
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
I agree with the fact that the 4th Gen rears came with the short fins, its how mine came off a 95 SS, dont know why though.
Hotrodboba400
Dec 10, 2019 07:07 PM
