Help bleeding Brakes!
Old Jul 28, 2008 | 04:25 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
I replaced both of the rear brakes and i dont have that good of a peadel i think that i have some air in the lines whats the best way how to?
PS: getting them wheel cylinders off suck!
thanks
kevin
Old Jul 28, 2008 | 04:53 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: Help bleeding Brakes!
well, if you installed wheel cylinders you should know were the bleeder valves are. just take a friend/family member and have them sit in the car. keep the car turned off. tell them to pump the brakes a few times. then open the bleeder valve and tell them to press and hold on the brakes. wait until it bleeds as much as its going to bleed and close the valve and tell your partner in the car to let off the brakes. repeat the process until the brake pedal gets firm. then try it with the car on.
Old Jul 28, 2008 | 06:15 PM
Well i did it some what but i did it with it running should i do it again with it shut off?
kevin
Old Jul 28, 2008 | 06:54 PM
yea, try bleeding the master cylinder too. should be bleeder valves on the porportioning valve. and make sure the cap is on when your bleeding.
83 Crossfire TA
Jan 3, 2016 01:26 PM
dbrochard
Sep 19, 2015 08:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
