Is this normal?
Old Aug 1, 2008 | 01:45 AM
Alaska Hwy 1Le's Avatar
Car: 91' Z28 1LE R7U
Engine: 350 ZZ6
Transmission: 6 Speed T56 Magnum
Axle/Gears: 3:42 posi G80/GU6
Is this normal?
I can't lock any wheels when hard on the brakes on dry pavement. It's a 91' R7U with the PBRs. They will lock in lower traction situations. I just put new pbr's on it and they still won't lock. They grab really good and they almost lock but not quite. Car tracks straight, doesn't pull or or anything when on hard. Lots of feel/response in pedal. Had different pads still no dice. No fluid loss either system is tight and bled. Master Cylinder maybe?
Old Aug 1, 2008 | 04:19 AM
Jix01's Avatar
Car: 1990 Pontiac Firebird
Engine: 305 5.0 TBI
Axle/Gears: 2.73 Open Diff.
Re: Is this normal?
both firebirds i have had have slid if you hit the brakes hard enough but maybe my ABS just didn't work in them...lol
Old Aug 1, 2008 | 12:58 PM
SteelTownMadDog's Avatar
Re: Is this normal?
Probably depends on the brake pads also. I still have the stock 10.5" front brakes on my 86 with a set of aggressive front race pads and can easily lock the fronts once they reach operating temps.
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
Stroopwafel
Sep 11, 2015 06:38 AM
